txrx Posted December 8, 2009 Share Posted December 8, 2009 (edited) Hi there, I'm using -P to run a python script to over ride the IFD's params for the image crop values to allow me to render out tiles for assembly once they're all done but when I use the below code regarding amending the file name... def filterCamera(): < get tile number > < set crop image values > etc. OriginalName = mantra.property('image:filename')[0] TileNameData = "0.0_0.25_0.5_0.75" TileFileName = os.path.splitext(OriginalName)[0]+"_"+TileNameData+os.path.splitext(OriginalName)[1] mantra.setproperty('image:filename',TileFileName) It still saves the output image with the original file name to disk from the IFD Am I making this change at the right place or using the wrong def for python filtering? Must admit I'm pretty new to Houdini so there's every possiblity I've got it wrong here Using build 10463 on win64 machines (yea, I know windows etc but there you go) Edited December 8, 2009 by txrx Quote Link to comment Share on other sites More sharing options...
symek Posted December 8, 2009 Share Posted December 8, 2009 Hi there, I'm using -P to run a python script to over ride the IFD's params for the image crop values to allow me to render out tiles for assembly once they're all done but when I use the below code regarding amending the file name... def filterCamera(): < get tile number > < set crop image values > etc. OriginalName = mantra.property('image:filename')[0] TileNameData = "0.0_0.25_0.5_0.75" TileFileName = os.path.splitext(OriginalName)[0]+"_"+TileNameData+os.path.splitext(OriginalName)[1] mantra.setproperty('image:filename',TileFileName) It still saves the output image with the original file name to disk from the IFD Am I making this change at the right place or using the wrong def for python filtering? Must admit I'm pretty new to Houdini so there's every possiblity I've got it wrong here Using build 10463 on win64 machines (yea, I know windows etc but there you go) http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=83286#83286 Quote Link to comment Share on other sites More sharing options...
