reuse point in pop network
imoh3n
hi.
in pop network i use a volume of points for source of emitter, i want to each point just emit a particle once. something like, don't reuse point in particle node.
i do something like that in sop network, create a group for points that id's, greater than the number of source points and use blast to delete particles in group, but i think there must be a better way.
i hope if somebody help me.
  On 12/9/2009 at 6:09 PM, imoh3n said:
hi.
On the popnet there is a parameter for Max Points that you set.
I'm not sure if I understand the question very well.
but if you are trying to emit on a specific frame what u are looking for is
lets say u only wonna emit as many points as your source, on frame 36;
Impulse Activation: $FF == 36
Impulse Birth Rate: $NPT
cheers,
selcuk
Here is an example. You basically need to delete all but the point you want to emit from on the frame you want to emit. In the delete SOP I am doing this by the expression:
$PT == ($F - 1) / 10
If the point number equals the frame number, then its kept and it emits a particle. All others are deleted. I divide by 10 just to slow down when each particle is emitted.
emitOneAtATime_001sl.hipFetching info...
you put a kill pop and use the following rule maybe
$ID >= npoints(opinputpath("../",0))
afterwards you can get rid of the unnecessary points in sops by using a similar expression in delete sop, such as;
$ID >= npoints("/obj/geo1/particlesource")
Edited by cellchuk
  On 12/10/2009 at 8:29 PM, imoh3n said:
in some situation it's maybe good, but i think, control of speed and number of emit is hard, especially if we have so many point for source of emitter.
if i get it right you should divide a numper of source points by the amount of frames you need to emit
like that:
noReusePoints.hipFetching info...
