Cyndre Posted December 31, 2009 Share Posted December 31, 2009 Hi, I am really struggling to get the HOT installed on version 465 under windows 7. I followed the instructions for binary installation as I don't understand the compile instrucitons from source. I have managed to get the example files to open in Houdini but when I start a new project and shift tab then enter Ocean it doesn't come up. Can anyone help me and explain what I am doing wrong? Quote Link to comment Share on other sites More sharing options...
Red_Glasses Posted January 13, 2010 Share Posted January 13, 2010 I am having the same issue as Cyndre... I have successfully used the Ocean Toolkit under Win Vista 64 in Houdini version 10.0.374 but now with a new system using Windows 7 and Version Houdini 465 I can not get it to work. I have downloaded new win 64 zip file for the Houdini version and edited the HOUDINI_PATH and the Path environment variables to point to the folder with no results. The Ocean SOP is not there. Example files load but the Ocean SOP does not appear. I would really appreciate any thoughts and help getting HOT to work in this configuration. Thanks.... Quote Link to comment Share on other sites More sharing options...
Div Posted April 28, 2010 Share Posted April 28, 2010 (edited) Hi, i'm desesperatly trying to install HOT for Houdini 10.0.465 on xp 64... I downloaded the binary distribution hotbin_win64_H10.0.465_1.0rc8 (seems to be the perfect one for my config) from the google code website and then, following HOT help ( http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ ) add the path to my PATH variable. When i add the HOUDINI_PATH variable and set it correctly, houdini doesn't want to start anymore after few errors' messages.... So i remove the variable, then houdini shows up but i can't make any of the examples' files to work... If someone succeed to install and use HOT within the same config, please show me the way... Thanks a lot Nico Edited April 28, 2010 by Div Quote Link to comment Share on other sites More sharing options...
exu Posted April 29, 2010 Share Posted April 29, 2010 Hi guys, i don't try install on Vista or Windows 7, but i recommend compile the source instead using binary distribution. but on mac and linux i have some problems that i solved login as root... So maybe it's a same kind of problem, did you try disable UAC (User Accout Settings) before compling it? or change permissions on some folders in $HFS (AKA houdini framework home), to see where is in your system, type HFS on terminal All Programs > Side Effects Software > Houdini X.X.XXX > Command Line Tools. there is a specifc topic here on odforce about it i hope that is help... Cheers On 4/28/2010 at 3:10 PM, Div said: Hi, i'm desesperatly trying to install HOT for Houdini 10.0.465 on xp 64... I downloaded the binary distribution hotbin_win64_H10.0.465_1.0rc8 (seems to be the perfect one for my config) from the google code website and then, following HOT help ( http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ ) add the path to my PATH variable. When i add the HOUDINI_PATH variable and set it correctly, houdini doesn't want to start anymore after few errors' messages.... So i remove the variable, then houdini shows up but i can't make any of the examples' files to work... If someone succeed to install and use HOT within the same config, please show me the way... Thanks a lot Nico Quote Link to comment Share on other sites More sharing options...
eloop Posted April 30, 2010 Share Posted April 30, 2010 Sorry I'm not able to keep up with the windows updates, I just don't have the spare time to generate binaries for all the platforms. I hope someone else can provide this service. This error sounds like you forgot to add the "&" at the end of the HOUDINI_PATH variable, it's important. -Drew On 4/28/2010 at 3:10 PM, Div said: Hi, i'm desesperatly trying to install HOT for Houdini 10.0.465 on xp 64... I downloaded the binary distribution hotbin_win64_H10.0.465_1.0rc8 (seems to be the perfect one for my config) from the google code website and then, following HOT help ( http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ ) add the path to my PATH variable. When i add the HOUDINI_PATH variable and set it correctly, houdini doesn't want to start anymore after few errors' messages.... So i remove the variable, then houdini shows up but i can't make any of the examples' files to work... If someone succeed to install and use HOT within the same config, please show me the way... Thanks a lot Nico Quote Link to comment Share on other sites More sharing options...
Div Posted April 30, 2010 Share Posted April 30, 2010 How stupid am i.... Thanks a lot the missing "&" was the problem... Quote Link to comment Share on other sites More sharing options...
