Point Age
PhasmaCeritus
You would have to go through pops, since sops cook geometry regardless it's current state ( x+=1 is not possible). You can simple create static particles, with age/life/custom attribute from you points and go back with them to sops. For some specific purpose chops are also in practice here, but I think pops are much more handy.
Another approach might be a sop solver dop, which can write "on a top" of a current geometry, but I'm not sure how about updating points number from sop during execution (turning on "Use Deform Geometry" is an option, but updates also attributes on existing points).
Anyway, popnet is fast and good solution.
errr... you mean in sops?
If you are only using sops, you can't. You can however get age (or geometry with history over time) by using dops. Specifically the sopsolver can do this for you.
Or you could trigger particles to be emitted from geometry at certain points in time. Those particles will record a life attribute that records the age inside - this is in the POP context.
hm, I have got the concept but could not figure it out in Houdini, sorry I am new here.
so let's say we have this line with points appearing in time (move the time slider); how do I get an age or creation frame attribute on these points?
thanks
Edited by PhasmaCeritus
you can find here an attribute called "born", which impulses to 1 for each new born point, is this is what you want?
Cheers,
Junaid
This is awesome what you did, but I still can't figure how can I get an attribute where I could store point creation frame number permanently.
For example spreadsheet at the end should look something like this:
P___birthFrame
1___1
2___10
3___35
4___45
5___63
6___75
7___120
8___130
9___150
where P is a point number and birthFrame is a custom attribute
