kumpa Posted January 21, 2010 Share Posted January 21, 2010 I have rigged character with animation (in place) and another character with simple chopnet to fetch animation from the other one and loop it. I made particle system with randomised Cd ® to offset animation cycle in chopnet with. But the problem is that animation cycles are all in the same phase....what the heck am i doing wrong ? See attached file. cheers k ant.zip Quote Link to comment Share on other sites More sharing options...
anim Posted January 21, 2010 Share Posted January 21, 2010 you cannot use instancepoint() to modify geometry because the main idea of point instancing is to have only one geometry in memory and use it on many points with only object level modifications (transforms, materials, visibility) (so you can at best have several different geos in subnet and just change visibility per instancepoint() to have appearance of modifying geometry, this is not your case of course) your scene is working perfectly on object level turn off display flag on Ant1/ant obj and turn on display flag on all Ant1 bones also check Renderable checkbox now render your scene and you can see that the bones are transformed per instance as you expect so only thing that does not work is SOP level deformation of the ant with the bones and that makes sense you have 2 options: 1.) break your ant into joints and parent each to corresponding bone, that should work with point instancing 2.) leave everything as it is, but use copystamping to generate different ant geometry per point but since your ant is made from separated meshes I'd go for 1. Quote Link to comment Share on other sites More sharing options...
kumpa Posted January 22, 2010 Author Share Posted January 22, 2010 hi bud ! What you are saying makes a lot of sense, but: 1. If i break it into pieces, would that chopnet doing animation lookup still get evaluated ? 2. How do you do copy stamping on object level ? cheers k Quote Link to comment Share on other sites More sharing options...
anim Posted January 22, 2010 Share Posted January 22, 2010 1. If i break it into pieces, would that chopnet doing animation lookup still get evaluated ? if every piece will be separate Geometry object paranted to the corresponding bone then yes you can even use your current bone objects and just change their geometry at sop level to corresponding ant part 2. How do you do copy stamping on object level ? not on object level, but evaluating bone transforms on per copy basis simply by copying the captured ant geometry but changing it's rig by copystamping look at attached file i haven't created example for the 1st method because it's a little hand work and i think you should get it from the description, but i encourage you to try the 1st method also because it is more memory efficient if you have large number of instances or heavy meshes Ant_copystamping.rar Quote Link to comment Share on other sites More sharing options...
kumpa Posted January 22, 2010 Author Share Posted January 22, 2010 You are amazing buddy ! Thank You Quote Link to comment Share on other sites More sharing options...
