keeping capture in place on loading
Hey,
OK, I must have done something wrong. After I capture the geo (in Char. Tools), I though I am supposed to set a keyframe on the Capture SOP's "Capture Frame". But nooo... upon loading, houdini recooked.......
Aren't there any better system than this...? Why do we have to remember to set a keyframe to hold the capture in place...? :/
A.
I swear Sesi should make this an easy feature somehow:
Whenever you're done with your weighting, SAVE OUT THE GEOMETRY!!!! I can't tell you how many times I had my weighting all set up great, and worked with the file for a week, then opened it up and BAM!, it's all screwed up, because I changed some channel somewhere. Saving out the geometry is the easiest and safest way to ensure your weighting doesn't change. The good thing is you can still paint/edit/whatever your capture, and then save out again.
-Jens
  • 1 month later...
  • 2 weeks later...
