Omy Posted February 13, 2010 Share Posted February 13, 2010 Hi im tryin to apply a break and tryin to keep the inside surface..but the geometry goes weird. I dont know why.Could anyone tell me the solution for it.I have attached the file below is ther a bug in houdini break node?? i done one test just by clickin a grid in shelf and applyin break and then by creating geometry node and creating a grid inside that and applying break for that.The former dint work and had weird extrusions outside,but the latter worked.Is that a houdini bug or wat is the actual problem?? Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted February 13, 2010 Share Posted February 13, 2010 The break and shatter tools are probably not the best solution for fracture although they do work... sometimes. Look for the John Lynch Voronoi Fracture OTL in the DOPS forum. I've also seen a lot of people doing cookies for fractures or hand modeling it. I would suggest to go with the Voronoi fracture OTL because it is really easy to use and extremely directable because you can input your own seed points at necessary locations. Jason Quote Link to comment Share on other sites More sharing options...
Omy Posted February 14, 2010 Author Share Posted February 14, 2010 The break and shatter tools are probably not the best solution for fracture although they do work... sometimes. Look for the John Lynch Voronoi Fracture OTL in the DOPS forum. I've also seen a lot of people doing cookies for fractures or hand modeling it. I would suggest to go with the Voronoi fracture OTL because it is really easy to use and extremely directable because you can input your own seed points at necessary locations. Jason ya but if u want to select a particular portion of the model u want to do shattering. then how do u go for tat. wat i alwys do is that. i select frm a break portion in break node and go for voronoi after tat.. that way i find very handy Quote Link to comment Share on other sites More sharing options...
rbowden Posted February 14, 2010 Share Posted February 14, 2010 ya but if u want to select a particular portion of the model u want to do shattering. then how do u go for tat. wat i alwys do is that. i select frm a break portion in break node and go for voronoi after tat.. that way i find very handy In that case you can use the old school method of using the cookie SOP to split the geometry in the portions that you want. After that, then you can use the voronoi fracture OTL by johner that mightcouldb1 mentioned to the pieces that you want. -Ryan Quote Link to comment Share on other sites More sharing options...
