Transforming point position to NDC
phong
Hi!
I searched through the expression functions, but couldn't find anything to transform a point from one coordinate system to another. In particular I want to transform a point from world coordinates to NDC. Is there an expression or do I have to go through the matrix stack?
Thanks,
Phong
if its at render time, there is a toNDC VOP which does this. If you want to do it at the SOP level, you could use your camera to project the uvs via uv texture SOP, then use a point SOP and in position replace $TX, $TY, $TZ with $MAPU, $MAPV, $MAPW.
I want to use it at the POP level :) would be too cool if there was a uvproject SOP..
Don't have to use projection in pops. In both Sops and Pops land you can use toNDC() with additional parameter for camera name:
$ndcP = toNDC("/obj/cam1", P);
You can paste it to inlineVOP to check how it works.
hth.
skk.
Edited by SYmek
hth.
skk.
Didnt know about that one, Thanks SYmek!
