Andrzej Posted March 5, 2010 Share Posted March 5, 2010 Hello I try to add material (.ifd file) to VRAYProcedural like in Mantra: Delayed Load and I don't know how to do this. I openGeometryObject(), addGeometry() and how to add material? Sorry, I thing this is easy but I can't find this in HDK documentation. Quote Link to comment Share on other sites More sharing options...
mrice Posted March 7, 2010 Share Posted March 7, 2010 Probably using changeSetting() Did you look through the header? In general there's lots of good info in the headers that doesn't make it into the doxygen docs. M Quote Link to comment Share on other sites More sharing options...
Andrzej Posted March 9, 2010 Author Share Posted March 9, 2010 Thanks I saw header but there aren't information about ifd file. I can add shader but i don't know how to load .ifd file and add shader and material from this file. Quote Link to comment Share on other sites More sharing options...
mrice Posted March 11, 2010 Share Posted March 11, 2010 Sorry can't help with that then, in the apprentice versions we can't play around with material archives. This would be a nice addition to the demoFile example. Quote Link to comment Share on other sites More sharing options...
pclaes Posted March 20, 2010 Share Posted March 20, 2010 Probably using changeSetting() I've been trying to get this thing working as well, something like this: UT_String full_material_path = "/obj/shopnet1/basic_surface_01"; openGeometryObject(); addGeometry(gdp_0, 0); changeSetting("shop_materialpath",full_material_path,"object"); closeObject(); But that does not work. In the VRAY_DemoBox.C example there is a short example of changing the shader: // Create a geometry object in mantra openGeometryObject(); // Add the geometry addGeometry(gdp, 0); // Change the surface shader setting changeSetting("surface", "constant Cd ( 1 0 0 )", "object"); closeObject(); But that is like hardcoding your shader in there and I've got a string that contains the path to the shader I want to assign. If I try to use: setSurface(full_material_path); I get the following error: mantra: VEX error: Unable to open /obj/shopnet1/basic_surface_01.vex Path not found mantra: VEX error: Unable to load /obj/shopnet1/basic_surface_01 Path not found From the ClusterThis procedural (in the VRAY_ClusterThisRender.C) I found out that: void *handle = queryObject ( 0 ); UT_String myMaterial; querySurfaceShader ( handle, myMaterial ); myMaterial.harden(); std::cout<<"myMaterial: "<<myMaterial<<endl; returns something like: myMaterial: "op:/obj/shopnet1/basic_surface_01/basic baseColor 0.899999976158 0 0 baseColorMap default.pic colorMapWrap repeat colorMapfilter catrom colorMapBorder 0 0 0 1 specType spec specularMap \"\" specMapWrap repeat specMapFilter catrom" This seems to be a much more detailed string (that contains all the parameters for the shader) that was assigned to the object in object level. So then I wanted to test if that passes on the information: void *handle = queryObject ( 0 ); UT_String myMaterial; querySurfaceShader ( handle, myMaterial ); myMaterial.harden(); std::cout<<"myMaterial: "<<myMaterial<<endl; openGeometryObject(); addGeometry(gdp_0, 0); setSurface(myMaterial); closeObject(); Which it does - so at this point it seems this is working - but this is still a global assignment. So now I tried to use my own string with the exact same output as what was returned from the querySurfaceShader(): UT_String full_material_path = "op:/obj/shopnet1/basic_surface_01/basic baseColor 0.899999976158 0 0 baseColorMap default.pic colorMapWrap repeat colorMapfilter catrom colorMapBorder 0 0 0 1 specType spec specularMap \"\" specMapWrap repeat specMapFilter catrom"; openGeometryObject(); addGeometry(gdp_0, 0); setSurface(full_material_path); closeObject(); Which does not work and brings me back to: mantra: VEX error: Unable to open op:/obj/shopnet1/basic_surface_01/basic.vex Path not found mantra: VEX error: Unable to load op:/obj/shopnet1/basic_surface_01/basic Path not found So I'm a bit stuck, does anybody know how to assign your own shader (to which you have got the full path in the scene) to geometry inside a VRAY_Procedural? You can recreate this problem scenario easily by using the VRAY_DemoBox.C as an example file. I have a suspicion the querySurfaceShader() returns more than just a string, but I do not know how to convert my own shaderpath into a formatted string of the kind that is required. It seems to be important to get the actual material back, but I do not know how to get to it. I think it has something to do with : http://www.sidefx.com/docs/hdk10.0/_o_b_j___node_8h_source.html#l00106 00836 // Get a node specified as a material 00837 SHOP_Node *getMaterialNode( fpreal now ); or perhaps: 00818 SHOP_Node *evalShaderString(UT_String &shader, 00819 int shop_type, fpreal now, 00820 const UT_Options *options, 00821 SHOP_Node *shop = 0); But I do not know how to use those functions. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
mrice Posted March 21, 2010 Share Posted March 21, 2010 (edited) So I'm a bit stuck, does anybody know how to assign your own shader (to which you have got the full path in the scene) to geometry inside a VRAY_Procedural? AFAIK that's not possible. When the procedural is run mantra only knows about your scene as it exists in the ifd. How about adding an empty object to the scene with your shader attached, then use queryObject and querySurfaceShader to get the shader in the procedural? My guess is that for material archives there's a way to include an ifd in another ifd. Maybe setting vm_embedvex on the rop with the method above would also work. Edited March 21, 2010 by mrice Quote Link to comment Share on other sites More sharing options...
pclaes Posted March 21, 2010 Share Posted March 21, 2010 AFAIK that's not possible. When the procedural is run mantra only knows about your scene as it exists in the ifd. How about adding an empty object to the scene with your shader attached, then use queryObject and querySurfaceShader to get the shader in the procedural? My guess is that for material archives there's a way to include an ifd in another ifd. Maybe setting vm_embedvex on the rop with the method above would also work. Hmmm, this makes sense. Thanks for the insight. Probably for each material I will have to have an empty object to reference, so rather than referencing the shader. I will reference the objects that have the shaders assigned to them. Hope it still works by passing custom variables to those shaders from within the procedural to overwrite certain parameters. Otherwise I will probably have to load the vex code from disk. Why did that work with the VRAY_DemoBox.C example then? // Change the surface shader setting changeSetting("surface", "constant Cd ( 1 0 0 )", "object"); 1 Quote Link to comment Share on other sites More sharing options...
pclaes Posted March 21, 2010 Share Posted March 21, 2010 Probably for each material I will have to have an empty object to reference, so rather than referencing the shader. I will reference the objects that have the shaders assigned to them. Hope it still works by passing custom variables to those shaders from within the procedural to overwrite certain parameters. This works, with the overwriting of attributes . Feels a bit like a hack, but now I understand it better. Quote Link to comment Share on other sites More sharing options...
symek Posted March 22, 2010 Share Posted March 22, 2010 (edited) My guess is that for material archives there's a way to include an ifd in another ifd. Yes, it seems to be, since this is what Houdini's own Delayed Load Archive SHOP is doing. Now, the question would be what is a code to include ifd in ifd file? Edited March 22, 2010 by SYmek Quote Link to comment Share on other sites More sharing options...
