bend a line or stick
Hi there,
I know this is a simple question, but I still dont know how to do it.
I just wondering is there an easy way to bend a line procedurally(very simple like the attachment)? Like you guys did in helical cable challenge.
Thanks,
Tong Le
Hi there,
Thanks,
Tong Le
Check out the Twist Sop
you could do it with exppressions but it would be a crazy long expression,
there is a couple of bend assets on the exchange that works a little differently to the native bend, and more like the max bend.
The base of a line or tube will not move when the object is bent - the pivot is at the base.
look for 'rk omni bend'
its a good exercise to make your own in VOPS if your into that sort of thing...
daniel phillis
daniel phillis
Thanks. I will give it a try! :)
Edited by Tong Le
Guest Swann
Nah, it just two short lines in pointSOP:
$TX * cos($BBY*ch("bend")) - $TY* sin($BBY*ch("bend"))
$TX * sin($BBY*ch("bend")) + $TY* cos($BBY*ch("bend"))
bend.hipnc
  • 5 years later...
