Camera parameters
Macha
I am writing a python script to convert voodoo camera tracking data to a Houdini camera. Getting the data across seems to work OK. The camera moves and wriggles in kind of the right manner.
However, I am a bit stuck with what exactly the corresponding Houdini parameters are. Voodoo gives me the following:
# f               : Focal Length [mm]
# fov             : Horizontal Field of View [degree] = (2*atan(0.5*Width*sx/f)*180/PI;
How do they relate to Houdini Focal Length and Aperture?
Then, it also gives me the rotation axis.
# (Ax, Ay, Az)    : RotationAxis2  [unit vector]
# (Hx, Hy, Hz)    : RotationAxis0 [pel] (including FocalLength, PixelSizeX, and Principal Point offset)
# (Vx, Vy, Vz)    : RotationAxis1 [pel] (including FocalLength, PixelSizeY, and Principal Point offset)
There's probably a neat matrix way to convert this into rx ry rz rotation angles. But for now I calculated angles this way:
def getangle(vec1, vec2):
    v1 = hou.Vector3( vec1 )
    v2 = hou.Vector3( vec2 )
    angle = v1.angleTo(v2)
    return angle
So far so good. Now for the confusion: Which two vectors do I choose to calculate the angles? Like this?
camera_rotation_rx = getangle( A, world_y_axis )
camera_rotation_ry = getangle( H, world_z_axis )
camera_rotation_rz = getangle( V, world_x_axis )
Or did I muddle up things there?
Edited by Macha
There's some info hidden in the docs about camera aperture, fov, etc:
http://www.sidefx.com/docs/houdini10.0/ref/cameralenses
Just glancing at that page, maybe
(H0x, H0y, H0z) : RotationAxis0 [unit vector]
(V0x, V0y, V0z) : RotationAxis1 [unit vector]
are more useful?
It says there that there's a python export script for blender, maybe that's worth a look if you don't mind cheating :D
Oh, stealing from Blender. Good idea Michael B)
It appears their camera transformation matrix setMatrix(Mathutils.Matrix(stuff)) with the values of this camera model looks like this:
[HOx,   HOy,  HOz, 0]
[-VOx, -VOy, -VOz, 0]
[-Ax,   -Ay,  -Az, 0]
[ Cx,    Cy,   Cz, 1]
My matrix skills are a bit, err, basic yet, so I guess in Houdini I'd have to use:
cam_mat = hou.Matrix4((
(HOx, HOy, HOz, 0),
(VOx, VOy, VOz, 0),
(Ax,   Ay,  Az, 0),
( Cx,  Cy,  Cz, 1)))
and then
mrot = cam_mat.extractRotates()
#or this
mrot = cam_mat.explode()
to get a rotation vector.
Does that sound about right?
Edited by Macha
Wohooo! I got it working! Well chuffed now. The camera appears to move the way it should.
Only thing is that f and fov thing that doesn't fit... Hmmm... I'll keep digging...
It looks like a trig problem. According to the docs this should be correct:
tan( fov*.5 ) = (aperture*.5)/f
so then
aperture = 2*f*tan(fov/2)
but it gives me a negative aperture...
Here's what I got so far (with manual fov)
Edited by Macha
What happens if you just take the absolute value of aperture?
Hmm, in that case I can only see 50% of what I should see. Hmmm. Hmmm.
Oh, hold on! Maybe it's a degrees/radians issue! I'll go try that.
Edited by Macha
