vbk!!! Posted March 18, 2010 Share Posted March 18, 2010 Hello, I would like to know how to achieve this simple shading with houdini For the moment it's done with Lightwave. The gradient is made based on the distance between a Null and the "spot" of the surface. But I don't know what the equivalent of the spot surface in houdini. If it's easy to make this effect with one point it becomes tricky (impossible) to make this with ... all the points of a curve for example. I wonder how difficult it could be in Houdini. Thanks for your Help Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted March 18, 2010 Share Posted March 18, 2010 Quick fun while waiting for renders. To switch between single null and multiple points on a curve, use the "Shade Mode" parameter on the grid object. Before rendering the multiple-point test, you have to save the point cloud from the Curve object. Sketched using VOPs to hopefully make it easier to follow. spot.hip Cheers. Quote Link to comment Share on other sites More sharing options...
vbk!!! Posted March 18, 2010 Author Share Posted March 18, 2010 (edited) thanks thanks thanks a lot. It's exactly the kind of hip file I want to studie wow ... watching the spotPointCloud shader, i think I will have some question for you sooner or later. For the moment I have to study the use of point cloud deeper ... Edited March 18, 2010 by vbk!!! Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted March 18, 2010 Share Posted March 18, 2010 watching the spotPointCloud shader, i think I will have some question for you sooner or later.For the moment I have to study the use of point cloud deeper ... Everything looks scary when done with VOPs, particularly, as is the case here, when there are couple of if() branches and a while() loop -- welcome to spaghetti land. That thing would be around 5 lines of VEX and much easier to follow. I'll post the VEX version when I get a chance. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted March 19, 2010 Share Posted March 19, 2010 Here's a VEX version that combines both of the previous shaders into one. I've added some comments and split it up into several functions for redability. The whole point cloud thing is happening inside the spot_pc() function. #define RAMPC_ARGS(name) name##b, name##k, name##v #define RAMPC_PARMS(name) string name##b[]; float name##k[]; vector name##v[] #define RAMPC_DFLTS(name) \ string name##b[] = {"linear","linear"}; \ float name##k[] = {0,1}; \ vector name##v[] = {1,0} // modulo operator float modulo(float a, { float r=a%b; return r<0 ? r+b : r; } // repeat: returns a sawtooth wave with the given period float repeat(float x, period) { return modulo(x/max(1e-9,period),1); } // rampc - solve a color/vector ramp vector rampc(float t0; string rampb[]; float rampk[]; vector rampv[]) { return spline(rampb,spline("linearsolve",t0,rampk),rampv); } // filter kernel applied to pointcloud lookups float kernel(float rad, d) { return 1.0 - smooth(0,rad,d); } // color-by-distance: pointcloud version (assumes handle is valid) vector spot_pc(int handle; float radius,spotsize; RAMPC_PARMS(r) ) { vector csum = 0; float wsum = 0, d, w; while(pciterate(handle)) { if(pcimport(handle,"point.distance",d)) { w = kernel(radius,d); wsum += w; csum += w * rampc(repeat(d,spotsize),RAMPC_ARGS(r)); } } return csum/max(1e-9,wsum); } // Both shaders combined into one surface spot ( // common parms RAMPC_DFLTS (ramp); // ramp used for coloring float spotsize = 0.2; // cycling period for ramp coloring string method = "null"; // shading method: "null" or "pc" // null object method string nullobj = ""; // object from which to measure distance // point cloud method string pc_file = ""; // point cloud file with spot points float pc_rad = 10; // maximum search radius int pc_npt = 2; // max num of points for search // emission for PBR engine export vector Ce = 0; // PBR: color will be assigned to emission ) { vector Pobj = ptransform("space:object",P); vector Cspot = 0; if(method=="pc" && pc_file!="") { int handle = pcopen(pc_file,"P",Pobj,pc_rad,pc_npt); if(handle>=0) { Cspot = spot_pc(handle,pc_rad,spotsize,RAMPC_ARGS(ramp)); pcclose(handle); } } else if(nullobj!="") { vector Pnull = ptransform(nullobj,P); Cspot = rampc(repeat(length(Pnull),spotsize),RAMPC_ARGS(ramp)); } Cf = Ce = Cspot; } Anyhoo... this way you can follow along in VEX in case you get tangled up in VOPs Here's an updated hipfile which can use any one of the three shaders (two VOP, one VEX). spot2.hip P.S: hmmm... @Marc: the old tag seems to have disappeared ... and the combination "( r )" gets expanded into a registered trademark symbol, hehe. Oh! and "b )" turns into "B )", lolz. Oh well, download the hipfile, the code is embeded in the shader. 1 Quote Link to comment Share on other sites More sharing options...
roughsporty Posted January 10, 2011 Share Posted January 10, 2011 Hi Mario, I saw your simple shader for a gradient setup. I'm using H11 and have created your setup and in works when the parameter is plugged in the color node of the lightning model. But in my scenario I would use the gradient for the alpha so that the surface "fades" with the background. So I have plugged it as it shows up in the screenshot. It doesn't work and I have no idea why. Thanks Quote Link to comment Share on other sites More sharing options...
roughsporty Posted January 10, 2011 Share Posted January 10, 2011 I've solved it Quote Link to comment Share on other sites More sharing options...
Valentino Posted February 20, 2011 Share Posted February 20, 2011 I've solved it can u share u solution please! Am trying to achieve the same effect Quote Link to comment Share on other sites More sharing options...
roughsporty Posted February 22, 2011 Share Posted February 22, 2011 can u share u solution please! Am trying to achieve the same effect Here is a little test scene. Just render "cam1" and look into the nodes. gradient_test.hipnc Quote Link to comment Share on other sites More sharing options...
