evgen Posted March 24, 2010 Share Posted March 24, 2010 Hi guys. I have a little problem with bezier curve. i can make sharp corner (A on image) while creating curve, but how i can change already created smooth vertex (B at image) to sharp (as A)? thanks Quote Link to comment Share on other sites More sharing options...
sidandmj Posted March 24, 2010 Share Posted March 24, 2010 you can try a point sop, put the point number in the group field, in this case 8 then change the "keep weight" to "new weight" and set the weight of the point to a very high value 100+ not sure if this is the best way but it is one way cheers Quote Link to comment Share on other sites More sharing options...
edward Posted March 25, 2010 Share Posted March 25, 2010 Or you can insert a point to the right and left of it in the curve. Quote Link to comment Share on other sites More sharing options...
evgen Posted March 25, 2010 Author Share Posted March 25, 2010 O, weight is really what i need. thanks Quote Link to comment Share on other sites More sharing options...
