mr_tsoi Posted April 2, 2010 Share Posted April 2, 2010 Good day to everybody! I've read Peter Claes's pdf doc and very intrested with that technique using high resolution 2d fluid containers. Does anybody know where from I can find up more complex information about this stuff? Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted April 2, 2010 Share Posted April 2, 2010 Here is a paper on ACM if you are a member: http://portal.acm.org/citation.cfm?id=1576246.1531347&coll=ACM&dl=ACM&CFID=148308&CFTOKEN=43940363 This video does talk about it, but it's only an overview. It's an interesting video because they talk about ILM's pipeline and how they are altering it to accommodate the use of the GPU to preform real time simulations. http://v.youku.com/v_show/id_XMTQ1MzQyODk2.html Also, I would assume that Peter would cite his sources at the end of his paper. So check out what he's reading as well. Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted April 2, 2010 Share Posted April 2, 2010 (edited) Here's someones homework: http://www.cs.umd.edu/class/fall2009/cmsc828v/presentations/Presentation2_Sep22.pdf They seem to give a decent overview, but you can probably find all of that in the SIGGRAPH paper that I linked to above. Edited April 2, 2010 by mightcouldb1 Quote Link to comment Share on other sites More sharing options...
mr_tsoi Posted April 2, 2010 Author Share Posted April 2, 2010 Here is a paper on ACM if you are a member: http://portal.acm.org/citation.cfm?id=1576246.1531347&coll=ACM&dl=ACM&CFID=148308&CFTOKEN=43940363 This video does talk about it, but it's only an overview. It's an interesting video because they talk about ILM's pipeline and how they are altering it to accommodate the use of the GPU to preform real time simulations. http://v.youku.com/v_show/id_XMTQ1MzQyODk2.html Also, I would assume that Peter would cite his sources at the end of his paper. So check out what he's reading as well. Thank you for the tips. What should I do to be ACM member? Default account does not allow me watch that mov? Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted April 2, 2010 Share Posted April 2, 2010 (edited) Thank you for the tips. What should I do to be ACM member? Default account does not allow me watch that mov? You have to sign up, its about 250 for a membership, or 40 for a student membership. Edited April 2, 2010 by mightcouldb1 Quote Link to comment Share on other sites More sharing options...
edward Posted April 5, 2010 Share Posted April 5, 2010 However, if you just want to look at SIGGRAPH papers, it's considerably cheaper. I pay about $50 USD/year and it makes the SIGGRAPH full conference pass cheaper as well. Student rates are lower as well I think. Quote Link to comment Share on other sites More sharing options...
mawi Posted April 5, 2010 Share Posted April 5, 2010 And here are two good paper resorces. http://trowley.org/ http://kesen.realtimerendering.com/ Quote Link to comment Share on other sites More sharing options...
