oldiesgoodies Posted April 2, 2010 Share Posted April 2, 2010 Hi I want to break an object but I want only some part of the object to be broken up. So I create a group and feed into the break sop. But for some reason the group is not listed in the "Group" text entry. I tried both point and primitive grouing but none helped. Is there any way to make this work? thanks Quote Link to comment Share on other sites More sharing options...
SpencerL Posted April 2, 2010 Share Posted April 2, 2010 Hi I want to break an object but I want only some part of the object to be broken up. So I create a group and feed into the break sop. But for some reason the group is not listed in the "Group" text entry. I tried both point and primitive grouing but none helped. Is there any way to make this work? thanks After your group SOP, feed that group into a delete SOP and set it to Delete Non Selected so you are just left with your group. Then do your break to that. Quote Link to comment Share on other sites More sharing options...
oldiesgoodies Posted April 2, 2010 Author Share Posted April 2, 2010 Hi thanks for the quick reply. I guess that could be a solution as well. How about the group stuff in the break sop? Is it supposed to do some other stuff rather than masking the break? Quote Link to comment Share on other sites More sharing options...
