Richey Posted April 7, 2010 Share Posted April 7, 2010 Hi guys, the topic describes my problem. The SHIFT Key doesn't work anymore - Only in Houdini. Also after reboot of my pc. Hope someone can help me Thx, Richey. Quote Link to comment Share on other sites More sharing options...
barad_dur Posted April 7, 2010 Share Posted April 7, 2010 Hi guys, the topic describes my problem. The SHIFT Key doesn't work anymore - Only in Houdini. Also after reboot of my pc. Hope someone can help me Thx, Richey. Well, you could try deleting your houdini folder to kill all your preferences in case something got rewritten there. It will rebuild when you fire Houdini up again. Mine, on Windows, is in C:\Documents and Settings\dabennet\My Documents and its the Houdini10.0 folder. I just delete the whole folder and re start Houdini and everything gets fixed. Other than that I have no idea why only your shift key is messed up in Houdini. Quote Link to comment Share on other sites More sharing options...
Richey Posted April 8, 2010 Author Share Posted April 8, 2010 Hi barad_dur, Thank you so far, but after deleting the folder Houdini won't start anymore Any other ideas? Quote Link to comment Share on other sites More sharing options...
old school Posted April 8, 2010 Share Posted April 8, 2010 (edited) Don't delete the houdini folder inside $HFS or the Houdini install directory. Do that and yes you can't launch Houdini. You want to work with the houdini10.0 or more generically the houdiniX.X folder in your $HOME directory. That's the houdini directory you want to delete. Btw I don't delete the houdiniX.X directory, I just rename it or move it out of there to test then drag back folders until it breaks Houdini. I have a "lot" of stuff in various houdini directories. I leave the default houdiniX.X directories mostly alone and have my own houdini_customX.X directories where I put working stuff and pick up by modifying $HOUDINI_PATH and it's variants. I guess a re-install of Houdini will fix the missing houdini dir in $HFS. Edited April 8, 2010 by old school Quote Link to comment Share on other sites More sharing options...
Richey Posted April 8, 2010 Author Share Posted April 8, 2010 I know that I have to delete the $HOME directory. Okay, after two tries (and fatal errors) Houdini starts with its standard settings. But the problem still exists Seems that I really have to reinstall. I guess a re-install of Houdini will fix the missing houdini dir in $HFS. Okay I will try it. Quote Link to comment Share on other sites More sharing options...
ben Posted April 8, 2010 Share Posted April 8, 2010 I know that I have to delete the $HOME directory. Okay, after two tries (and fatal errors) Houdini starts with its standard settings. But the problem still exists Seems that I really have to reinstall. Okay I will try it. Quote Link to comment Share on other sites More sharing options...
Richey Posted April 9, 2010 Author Share Posted April 9, 2010 No text ? By the way: The SHIFT Key works for marking text, but not for Hotkeys and capital letters. Quote Link to comment Share on other sites More sharing options...
Richey Posted April 10, 2010 Author Share Posted April 10, 2010 OMG. The reason for my problem is my firewall When I turn the firewall off, the shift key works, if I turn it on, the shift key doesn't work. I think I have to configure it the next days. I'm using the Comodo Internet Security (if you have the same problem). Quote Link to comment Share on other sites More sharing options...
