for each sdf
Macha
I have a fractured object sim, the result of which I saved out as a bgeo series.
Now I want to use these objects in another smoke sim.
But calculating one big massive sdf for this geometry (consisting of many small pieces) is not a good idea.
Can I loop through each object and create a small concise sdf for each object somehow. I guess there is some automatic way of doing this because it happens when we create fractured objects.
Or is there a different method?
Edit: Maybe just use the fractured object node...silly me...
Edited by Macha
Yep, definitely work.
Also I recommend NOT using group names at all for the foreach iteration, instead use a Primitive group attribute, you can create one using the connectivity sop if you don't have one already, it'll be MUCH faster than using foreach per group name.
