Texture in SOP
draetsch
  • 2 weeks later...
Hey there
I'm not familiar with the lava tutorial, but I assume it uses some sort of procedural texture to generate the lava patterns right?
If you want to use a texture, then you should be able to just put down a parameter VOP (set to 'file') and wire that into the place that the procedural pattern gets put.....
....erm.... not knowing what its doing though I'm not sure if that's much help..
Cheers
Marc
