sparkChan Posted April 19, 2010 Share Posted April 19, 2010 hi, when I used the Group Geometry SOP to delete the groups in the ForEach node, the primitives are only cleaned up, but the groups which keep the primitives remain. seeing the nodes I used a red marker thanks delete_unused_group.hipFetching info... Quote Link to comment Share on other sites More sharing options...
Macha Posted April 19, 2010 Share Posted April 19, 2010 Are you trying to delete a group that belongs to the groups you are looping through? I'm not sure you can do that. How about tagging the groups and deleting them afterwards. Quote Link to comment Share on other sites More sharing options...
sparkChan Posted April 19, 2010 Author Share Posted April 19, 2010 On 4/19/2010 at 1:39 AM, Macha said: Are you trying to delete a group that belongs to the groups you are looping through? I'm not sure you can do that. How about tagging the groups and deleting them afterwards. I just want to delete the existing group using the Group Geometry SOP, under Edit Tap and Delete Tap. Although the primitives was cleaned up from the group, the group remain existing. Quote Link to comment Share on other sites More sharing options...
kumpa Posted April 19, 2010 Share Posted April 19, 2010 a bit off topic, but what is best way to delete empty groups ? cheers k Quote Link to comment Share on other sites More sharing options...
johner Posted April 19, 2010 Share Posted April 19, 2010 On 4/19/2010 at 2:30 PM, kumpa said: a bit off topic, but what is best way to delete empty groups ? cheers k A Delete SOP with default settings will do it. There's a parameter to "Delete Unused Groups". Quote Link to comment Share on other sites More sharing options...
