cspears2002 Posted May 3, 2010 Share Posted May 3, 2010 Hi, I'm trying to create a puff of smoke that comes out of an animated box. I parented a sphere to a box object with the top removed. The sphere is the smoke source. I added the box to the DOP network as a passive RBD object. However, the smoke still flows through the box's walls. Plus, the RBD object seems to be blocking the smoke somehow, which is strange because I turned off volume based collision detection. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
RontheDon Posted May 4, 2010 Share Posted May 4, 2010 Hi Christopher, should be fairly simple to achieve There is only a few things to look out for: - box needs some sort of "thickness" => i.e. polyExtrude - ur "static" RBD needs to have "use deforming Geometry" enabled (also try and avoid animating geo on SceneLevel whilst using DOPs) - same goes for your smoke source object - fluid container needs to be big enough to contain produced smoke at all times that should be it. cheers Quote Link to comment Share on other sites More sharing options...
cspears2002 Posted May 9, 2010 Author Share Posted May 9, 2010 Hey, I took RontheDon's advice and have met with some success! Unfortunately, I still get some smoke leaking through my box! I cranked the divisions under the Collision/Volume tabs for my RBD Object up to 70, but I still get some leakage. Plus, when I crank up the divisions, my sim takes longer to cook. Any advice? Thanks. Hi Christopher, should be fairly simple to achieve There is only a few things to look out for: - box needs some sort of "thickness" => i.e. polyExtrude - ur "static" RBD needs to have "use deforming Geometry" enabled (also try and avoid animating geo on SceneLevel whilst using DOPs) - same goes for your smoke source object - fluid container needs to be big enough to contain produced smoke at all times that should be it. cheers marc_smoke_pump_v05.hipnc Quote Link to comment Share on other sites More sharing options...
RontheDon Posted May 10, 2010 Share Posted May 10, 2010 Hey Christopher, I still get some smoke leaking through my box! This is due to the thickness of the box wall on the bottom. If you look at your result of the cookie u are using to create ur box in wireframe, you will notice, that the sides are a lot thicker then the bottom. Generally speaking the smaller (and therefore also thinner) an object is the higher res the sampling grid needs to be to sample it accurately. => to keep the divisions lower adjust the box thickness of the RBD object Plus, when I crank up the divisions, my sim takes longer to cook This is normal, as more data needs to be processed, however you can majorly speed up DOPS by caching out your collision object to disc. Hope this helps cheers Quote Link to comment Share on other sites More sharing options...
cspears2002 Posted May 12, 2010 Author Share Posted May 12, 2010 I made the walls thicker and that didn't work. I increased the divisions in the collision geometry up to 100, and that didn't work either. I adjusted the sub steps on the AutoDopNetwork. When that didn't work, I played with the sub steps on the RBD Solver and the Pyro Solver. Not sure what I am doing wrong... marc_smoke_pump_v07.hipnc Quote Link to comment Share on other sites More sharing options...
Nibbler Posted May 13, 2010 Share Posted May 13, 2010 (edited) cspears2002: I think density penetrates box because of how you made it using cookie in sops, if you add a point sop with normals you'll see the normals on the wrong side of geometry Edited May 13, 2010 by Nibbler Quote Link to comment Share on other sites More sharing options...
RontheDon Posted May 14, 2010 Share Posted May 14, 2010 cspears2002: I think density penetrates box because of how you made it using cookie in sops, if you add a point sop with normals you'll see the normals on the wrong side of geometry good point, I didn't check on the normals. All I could see in the old file was that the collision geometry wasn't detailed enough hope the normals worked. cheers Quote Link to comment Share on other sites More sharing options...
