Texture from points onto copied objects
fuzzylogic
Sorry if this has been posted before, it should be simple (I think) but I can't get it to work.
All I want to do is copy cubes onto points of a grid and have those cubes coloured the same as the point colour of the texture applied to the grid. Simples no?
Please help
Fz
Please help
Fz
Hi!
yes, it's simple. You just have to go to the attribute tab on your CopyNode and turn on "Use template Point Attributes"...
I've attached a file, just in case you need (I also commented and used explicit names)
boxToGridColored.hipnc
Be cool
Awesome, thank you... it seems I need to texture the picture at obj level not at sop level.
Next question is how do I move each cube depending on the colour of the cube.
If I texture the cube at obj how can I copy the colour info into a transform node for each individual cube and move it on the z-axis? Mrp
FZ
there is a couple of ways, but the easiest/fastest would be to move individual points according to the color prior to Copy SOP
there are even special attributes you can create on points prior to copy SOP to do other things like transform, scaling, rotating (trans, pscale, scale, N, v, orient, rot)
but if you want to use texture info to do other things, you'll need to use Copy Stamping Technique, which is very powerful, but i would use it as the last option, because it is the slowest of mentioned ways
(if you do a little search in forums, there is huge amount of threads about copying, copystamping, instancing, also in help trere is valuable info, also many tutorials on web)
here is an example of texturing the grid points at SOP level as well as pushing them along normals according to texture luma
then copying and coloring boxes on them
boxToGridTextured.hipnc
Hey Anim I like the way you name and organize your nodes ;)
Nice example you gave! A bit out of my league yet, with that Vop SOP... anyway, I was thinking in a different and (IMO) easier approach... if what he wants is to be able to move certains points along the z-axis, according to color information, couldn't he just randomly (or any other way) color the grid points and then use a partition node, with the rule "group by color" to create groups that would then be feed into a transform node and moved?
This is an answer and a question at the same time... ;) eheheh
- sorry if this is a bit of an hijack of your thread fuzzylogic!
:) a little leftover from your example
he can color it randomly, but he want to color it by texture as he said
so either VOP SOP (very fast) or Attribute Create SOP with tex()/pic() expression (very slow)
it won't help you to group by colors, it'll just create many groups. You still need to access the color info to get its value and move points by it, then again either VOP SOP or Point SOP or Copystamping
there is many ways to do this, but i think VOP SOP is the easiest/fastest one
ok, maybe not easiest for the beginner but deffinitely worth learning it
Ahhh... ok! Your explanation makes perfect sense!
I see I can't run forever from VOP's... thanks for taking the time to explain this! :)
