Question about "I" variable
kursad
Hi
I have started working on a shader. I can normally get what I want by creating a vector by substracting position "P" from position "eye". I also wanted to use the "I" variable described as "direction from eye to surface". But when I use it as part of a dot product I am not getting anything close to what I think I should be expecting. As you can see from the picture the upper example is wrong, and the bottom one is right.
I thought that the "I" variable was same as Renderman`s "I" variable
thanks
Edited by kursad
Just to complete the thread, I is indeed the vector from the camera to the current shade point. The wrong direction to compute the dot product with the surface normal. You need to negate the I vector so that it is a new vector going from the shade point to the Eye.
Finally you need to normalize both the negated I and the surface normal or your dot product won't return a sensible value (unless that is what you want). The I vector holds the distance from the Camera to the current shade point as it's magnitude.
old school, thanks for the tip, I did not know about the length aspect of that vector
