seth_ro18 Posted May 26, 2010 Share Posted May 26, 2010 Hi, I have a DOP simulation in which I would like one of my SOP Solvers to affect *all* the geometry in my sim, even the static objects. Is this possible? Right now, it only "sees" and updates the active objects, which is generally desired, but not for this particular case. Thanks! Quote Link to comment Share on other sites More sharing options...
old school Posted May 27, 2010 Share Posted May 27, 2010 On the Static Object DOP, try enabling "Use Deforming Geoemtry" to see if that works. You can modify the geometry all you want on a Static Object but if "Use Deforming Geometry" is off, it won't update the geometry to the simulation that you are driving in to it. Quote Link to comment Share on other sites More sharing options...
anim Posted May 27, 2010 Share Posted May 27, 2010 Deforming Geometry usually don't work with SOP solver, because it is repeatedly reading geometry from SOPs and that way resetting Geometry generated by SOP solver on previous timestep but what's probably happening in your case is that you are creating static RBD by unchecking Create Active Object on RBD object actually the Active Value of DOP objects is what tells any solver whether to solve it or not, so if it's not active, the object will not be solved the key is to create Static RBD Object, keep it's Activness to 1 and use SOP solver on that staticRBD_SOP_solver.hip Quote Link to comment Share on other sites More sharing options...
anim Posted May 27, 2010 Share Posted May 27, 2010 and if you want to use the same sop solver on all objects, not only in static branch, you can use SOP solver in all branches you want but point all of them to one SOP Network which will be used to solve them all like in this file i am not sure by the expression in the sopnet1, it gives some warning, but it works (i just copied/pasted working network from SOP solver ) staticRBD_SOP_solver2.hip Quote Link to comment Share on other sites More sharing options...
seth_ro18 Posted May 27, 2010 Author Share Posted May 27, 2010 Thanks, that's helpful. It answers my question that turning off the Active Value makes the solvers ignore the object completely. In my sim, I'm deactivating objects with the RBD Auto Freeze node, so I'll have to find a workaround with groups or such to keep those objects active for the particular solver. Quote Link to comment Share on other sites More sharing options...
