kill particles
roughsporty
I have a huge particle simulation and therefor I render it out to bgeo and seed variations with the wedge rope. I though it would be great
to kill every particles which is out of the camera view. My camera is not animated and has a resolution of 800x600. I have to group
those particles with a group node and then kill that stuff but I have no idea which expression I should use to find those particles?
I think I loosely remember a nice example from someone around here, and what they did was something clever like this:
- Create a UV Texture SOP to apply the UV attribute to geometry using Camera projection (from the UVTexture SOP use the option Perspective from Camera...I know you probably knew this but it might help someone else)
- Now, just delete those particles with a uv[0] or uv[1] attribute value below 0 or above 1 (i.e. particles that are outside the camera projection, so their UV attribute is not between 0 and 1)
- Do the victory dance B)
There are a lot of smart people around here. I get surprised almost every day. I´m just a replicant (damn you, Voight-Kampff)
Hope this helps.
I guess thsi is possible in houdini.
Create a geometry that has a shape of your camera view then kill anything outside of the geometry.
Very possible indeed, but it is computationally more expensive to group by object than it is to delete based on a uvw attribute (the w will allow you to clip in depth) - with very large particle counts grouping by object is slow. I generally create a camera that is parented to my view camera and offset it in z a little bit so I have a bit of overshoot when uv's are projected. You can get similar behaviour using the "w", but not quite the same.
