Netvudu Posted June 17, 2010 Share Posted June 17, 2010 Hi, I´m having some problems to copy letters over points. I want to copy each letter over a different point. I´m using the traditional method of using the Primitive SOP with Do Transformation activated and connecting the points to the second node input. This method more or less works but it tends to disalign some letters when I create some particle effects on the template points. I figured I could try a FOR EACH SOP copying each letter over a different point one by one. I already separated each letter into a different group via the Connectivity and Partition SOPs method. Which nodes should I use inside the FOR EACH SOP? Some sort of Copy or rather a Transform SOP for different point numbers? Could anyone enlighten me with a simple example that copies two or three letters over a few points so that letter 1 is copied over point 1, letter 2 over point 2, etc? Thanks! Quote Link to comment Share on other sites More sharing options...
Netvudu Posted June 17, 2010 Author Share Posted June 17, 2010 (edited) well, I solved my aligning problems, but I would still like to know what was the ForEach proper way of doing it to become a Houdini guru around the year 2514 Edited June 17, 2010 by Netvudu Quote Link to comment Share on other sites More sharing options...
anim Posted June 17, 2010 Share Posted June 17, 2010 why not just use Copy SOP and copy stamping? what benefits do you expect from ForEach? of course for one polygon letters the fastest way is Primitive SOP Quote Link to comment Share on other sites More sharing options...
Netvudu Posted June 17, 2010 Author Share Posted June 17, 2010 why not with Copy SOP? Well, obviously because this morning I was thick as a brick I just did it and it´s really simple with a single stamp. I thought it would be a good chance to properly learn the For Each SOP...next time Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted June 23, 2010 Share Posted June 23, 2010 why not with Copy SOP? Well, obviously because this morning I was thick as a brick I just did it and it´s really simple with a single stamp. I thought it would be a good chance to properly learn the For Each SOP...next time That's a very simple example "how to copy with for each". Notice that forEach SOP only works with primitives. So it would be a lot harder to make a good copy tool with points. Then this example show how to copy on primitives. For make it clear: inside has a "prim" function. That returns the centroid of a primitive. Cheers forEachCopy.hipnc Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted June 23, 2010 Share Posted June 23, 2010 Oh sent it with the cheese file from sidefx. My mistake. Huhauahuah! forEachCopy.hipnc Quote Link to comment Share on other sites More sharing options...
