breeder Posted June 28, 2010 Share Posted June 28, 2010 Hi i'm new here , i have one question. I assigned checker material to my object. Now i want to transfer texture color information to model (primitive color) , and to be able to select groups with particular color with partition sop. How to do this? Thanks Quote Link to comment Share on other sites More sharing options...
Macha Posted June 29, 2010 Share Posted June 29, 2010 I used point uv in this example, but a better choice would be vertex uvs. Same principle though. texture.hipnc Quote Link to comment Share on other sites More sharing options...
breeder Posted June 29, 2010 Author Share Posted June 29, 2010 Thanks I'm new to houdini , so i'm finding my way around. I have another question about dysplaying textures in viewport. When i adjust checker frequency on checker "texture based" material , how to see update in viewport dysplay? How to see in viewport procedural checker material , i only get flat color? Quote Link to comment Share on other sites More sharing options...
Macha Posted June 29, 2010 Share Posted June 29, 2010 I don't know about procedural, but if it has a texture, use can use the UVQuickShade node. In the specific case of the checker procedural, I think that the Check Frequency of the material is directly related to the uv range in the uvproject sop. So, to visualize it you could do some node and expression acrobatics by creating a second uvproject node (for display) and divide the max of both U and V range by the materials Check Frequency. That's not a very good way of going about though and perhaps you are better off using the Render preview pane, perhaps with a custom fast render node for that specific purpose. Quote Link to comment Share on other sites More sharing options...
breeder Posted June 29, 2010 Author Share Posted June 29, 2010 About first problem texture>primitive transfer. Why i need big geometry resolution for this to work. If i have basic check texture , 4 fields(2 white , 2 black) , and i have 4 polygon grid , this method don't work.Why? Thanks Quote Link to comment Share on other sites More sharing options...
breeder Posted June 29, 2010 Author Share Posted June 29, 2010 Ok , problem was what "tex" interpolate color , and "texni" don't. So i used expressions: texni("gBWCHECK.rat",$MAPU,$MAPV,r) ...etc Quote Link to comment Share on other sites More sharing options...
