nahee Posted July 7, 2010 Share Posted July 7, 2010 Would this be possible? If not would a terminal be possible inside a pannel so we could use terminal vim? Quote Link to comment Share on other sites More sharing options...
symek Posted July 7, 2010 Share Posted July 7, 2010 Generally speaking it would be awesome to have Qt type pane, I'm not sure if that's reasonably doable though... Quote Link to comment Share on other sites More sharing options...
lisux Posted July 7, 2010 Share Posted July 7, 2010 Would this be possible? If not would a terminal be possible inside a pannel so we could use terminal vim? I think is doable, but I prefer to have vim in the editor widget before. Quote Link to comment Share on other sites More sharing options...
nahee Posted July 23, 2010 Author Share Posted July 23, 2010 I think is doable, but I prefer to have vim in the editor widget before. What do you mean by "editor widget"? Do you mean to have vim as text editor when you alt+F3? Quote Link to comment Share on other sites More sharing options...
lisux Posted July 23, 2010 Share Posted July 23, 2010 What do you mean by "editor widget"? Do you mean to have vim as text editor when you alt+F3? Nope I mean that you have a way to change the default editor to work in vim mode. for instance in the preferences in the misc tab you can have an option to set editor s Vim . So when you open it using Alt-E, or the editor embedded in the shelf tool editor dialog, it load a vim buffer and can use your vim setting. Quote Link to comment Share on other sites More sharing options...
nahee Posted July 23, 2010 Author Share Posted July 23, 2010 Nope I mean that you have a way to change the default editor to work in vim mode. for instance in the preferences in the misc tab you can have an option to set editor s Vim . So when you open it using Alt-E, or the editor embedded in the shelf tool editor dialog, it load a vim buffer and can use your vim setting. I would love to get this going, however I don't see any txt editor related stuff under preferences>misc: Quote Link to comment Share on other sites More sharing options...
