Lambo
Lutze
did you create that shader yourself, and if you did, did you start with any of the materials inside Houdini, and if you did, which one? :P
It took 28 min on my 8-core machine with 20 Pixel Samples and 4 Min Ray Samples.
The shader is the basic vex metal shader out of the box with no modifications. I am still learning the depths of shader writing so I had to use the prebuild ones.
Edited by Lutze
