dilation by thickness
MENOZ
hello
I'm trying to figure out a way to modify the thickness of the lines in comp.
http://graphics.pixar.com/library/ToonRendering/paper.pdf
I decided to try in houdini cops.
once I have my clean contour lines, I use the dilate/erode node, but i want to modify the size value according to the black and white map. I tried with expression
tex(filename, U, V, color_type)
tex("/img/comp1/map_bw_jpg", 0, 0, L)
I tried to change values U and V inthe expression but nothig seems to happen.
how can I do to make it works?
thankyou
hello
thankyou
Pipe the image into the mask-input.
EDIT.
Dont forget to change the Operation Mask parameter under DilateErode->Mask->Oparation Mask, if you want to mask with something else then alpha.
Edited by mawi
EDIT.
this doesn't work.
I dont't want to maks the effect, I want to modulate the "size" parameter.
