spinda Posted July 26, 2010 Share Posted July 26, 2010 Dear all: I can trace HDK's code with GDB in Ubuntu, but I don't know how to trace it by Visual Studio in WindowsXP. I had set the "Additional Include Directories" and "Additional Library Directories" of project's properties of Visual Studio. But I can't build it successful...@@ I also had fellow this page's steps(http://www.sidefx.com/docs/hdk10.0/hdk_intro_compiling.html) and compile out a "SOP_Star.dll" in debug mode. But I also don't know how to trace "SOP_Star.C" when Houdini using SOP_Star.dll. Could anyone tell me how to trace "SOP_Star.C" in Visual Studio when Houdini is using "SOP_Star.dll" and Houdini is NOT crash. And Build HDK in Visual Studio successful. Thanks, Best Regards, Quote Link to comment Share on other sites More sharing options...
edward Posted August 1, 2010 Share Posted August 1, 2010 Here's one possible (untested workflow): - Make sure you're using Visual Studio 2005 - If you're using a 64-bit Houdini build, make sure you you have the 64-bit compiler installed. Type "%MSVCDir%\bin\amd64\cl" at the command prompt. - Edit code in GVim - Compile with "hcustom -g <FULL_PATH>/SOP_MyNode.C" - Run Houdini - Attach to Houdini process with the Visual Studio 2005 - Open SOP_MyNode.C and put a breakpoint in cookMySop() Quote Link to comment Share on other sites More sharing options...
