twist in curved tape
syzmatrix
Hi everyone,long time no see. I have a little problem in Houdini. Assuming there is a curve, resampled, transformed,merged and skined,to generate a Tape. Now some of the tape face should be twisted. So how can i get each pair of points and rotate them (their center point is the rotate center and there skined point normal define the construction plane)
thanks in advance.
untitled.hip
  • 1 year later...
This is a super useful little technique for me. I`m trying to create a host of deformations which will follow curves.
Something I dont understand about this setup is that if I copy a box onto the points, rather than a line, I get issues with orientation.
I cant work out how to make sure the box is copied to the points in such a way they follow the direction of the curve, as well as twist with the normals.
Anyone have any insight into this?
box_twist.hipnc
  • 3 weeks later...
