Blend > houdini
haris2
  • 2 weeks later...
  • 2 weeks later...
  • 1 month later...
I suggest you to use a latest Blender 2.5 beta, because there is the correct obj-exporter. If you're using stable 2.4, you could use 2.5 for export only. When you are exporting there are several export options, I generally use "selection only" option. So, you could export file once, load it in file-SOP node and then rewrite that file, and push the "reload" button in SOP node when you change export properties which are to play with. :lol:
  • 2 months later...
