pencha Posted September 30, 2010 Share Posted September 30, 2010 I want to render, using mantra not wren, and using a non-ortographic camera, lines with a width of say 2 px, no matter how close or far they are from the camera. I assume the way to go would be an expression that modifies the width attribute of every point (in between the points I don´t really care about "correctness") based on the distance lens and aperture of the camera. Anyone out there has already got something like this working, or a better idea in how to achieve it? Thanks! Quote Link to comment Share on other sites More sharing options...
rdg Posted October 1, 2010 Share Posted October 1, 2010 in vops transform the points of your line into camera space. use z and some user defined factor to set the width attribute to match the desired width. Quote Link to comment Share on other sites More sharing options...
pencha Posted October 1, 2010 Author Share Posted October 1, 2010 (edited) in vops transform the points of your line into camera space. use z and some user defined factor to set the width attribute to match the desired width. Thanks rdg, that´s what I´m doing right now, but I don´t know how to get the correct factor. It would be hard to cheat as I have lots of lines with VERY different z values (and so the perspective wildly affects the resulting width in the render). Edited October 1, 2010 by pencha Quote Link to comment Share on other sites More sharing options...
jacob clark Posted October 1, 2010 Share Posted October 1, 2010 Hi Pencha, I believe you want to divide your aperture by the distance to camera, and then divide by the focal length. This will work in X (and y if you are rendering a square image). For Y you need to do the same, but also multiply against the x/y resolution ratio. (And pixel aspect if other than one) Though, if it's just width, I guess just calculating the X scale will be fine... good luck! Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted October 1, 2010 Share Posted October 1, 2010 Georg's solution is the way to go I think (except you don't need to use VOPs if you don't feel comfortable there). You mention that you already tried it but it didn't work, so I'm thinking maybe you misunderstood some aspect of it. The relationship between the projected width and the distance from camera (or "depth") is linear, so all you need to correct the foreshortening it is some constant factor of depth. That's it (as Georg mentioned). One way to get depth into your geometry (without using VOPs) is with the UVTexture SOP, set to "Perspective From camera". In this case, the 'w' component of the uv's that it produces is the depth -- a scaled version of which you can use directly as the curve's "width" attribute. The only thing to watch out for is the fact that "width" is a point attribute, and so will be interpolated linearly by mantra. This is fine if the thing connecting any 2 points is a straight line, but not if it's a curve. So if you're using NURBs or Bezier curves you'll have to refine or resample them until each segment is close to a straight line. Here's a test without perspective correction: And here it is with the correction applied: ...and the hip file: camwidth.001.hip HTH. 2 Quote Link to comment Share on other sites More sharing options...
pencha Posted October 1, 2010 Author Share Posted October 1, 2010 (edited) Thanks again rdg, thanks Jacob and gracias Mario! Just needed the aclaration that the relationship in this case was linear, problem solved. I was studying light attenuation in real world photography and then switched to this, overcomplicating things (1/distance squared is the attenuation factor you need to compensate using real-world lights). ps: Never thought about solving this without VOPS! Nice file Edit: In case it´s useful for someone, If zooming is needed, dividing Mario´s expression result with the focal length seems to work OK Edited October 11, 2010 by pencha Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted October 10, 2010 Share Posted October 10, 2010 Georg's solution is the way to go I think (except you don't need to use VOPs if you don't feel comfortable there). You mention that you already tried it but it didn't work, so I'm thinking maybe you misunderstood some aspect of it. The relationship between the projected width and the distance from camera (or "depth") is linear, so all you need to correct the foreshortening it is some constant factor of depth. That's it (as Georg mentioned). One way to get depth into your geometry (without using VOPs) is with the UVTexture SOP, set to "Perspective From camera". In this case, the 'w' component of the uv's that it produces is the depth -- a scaled version of which you can use directly as the curve's "width" attribute. The only thing to watch out for is the fact that "width" is a point attribute, and so will be interpolated linearly by mantra. This is fine if the thing connecting any 2 points is a straight line, but not if it's a curve. So if you're using NURBs or Bezier curves you'll have to refine or resample them until each segment is close to a straight line. Here's a test without perspective correction: And here it is with the correction applied: ...and the hip file: camwidth.001.hip HTH. I have to say that is amazing.... so simple... so cool... and so random how I came across from what I searched for. -inadvertently thanks Quote Link to comment Share on other sites More sharing options...
