goggles Posted October 7, 2010 Share Posted October 7, 2010 Hello all, I'm using an instance node in point instance mode to copy the output of another sop onto it. The material has displacement on it but it seems to me that all the instances are being displaced in exactly the same way, i.e. the same deformation on every instance. I am assuming that is because the noise values (that are used for the displacement) are being looked at in local space, how would I make it so that it was in global? Also the object I am using to copy the instances onto has color attributes on the points but they are not inherited by the instances. Any suggestions how to accomplish this? Many many thanks! Quote Link to comment Share on other sites More sharing options...
anim Posted October 7, 2010 Share Posted October 7, 2010 there is instancepoint() expression which gives you ptnum of current point the geometry is instanced onto you can use this in offset attribute for your displacement to randomize displacement for each point in similar way you can lookup for color or other attributes on instance points simply by putting something like: point("../instance_points", instancepoint(), "Cd", 0) point("../instance_points", instancepoint(), "Cd", 1) point("../instance_points", instancepoint(), "Cd", 2) in color parameter of surface shader on your instances transforms can be automatically inherited by instances if certain attributes (like N, up, v, orient, rot, scale, trans) exist on instance points, more info is in help or in forums Quote Link to comment Share on other sites More sharing options...
glomm Posted October 7, 2010 Share Posted October 7, 2010 you can create attribute on points and use it to offset noise in shader Quote Link to comment Share on other sites More sharing options...
pclaes Posted October 7, 2010 Share Posted October 7, 2010 (edited) Have a look at the files attached in this post (all the way at the bottom). http://www.peterclaes.be/blog/?p=34 They use the instancepoint() expression to look up which procedural shader to load, using something along the lines of: point("obj/my_template_pts",instancepoint(),"instancetype",0) There is an example with lights that looks up the point color for the color of the light: Inside of the light's color: red: point("obj/my_template_pts",instancepoint(),"Cd",0) green: point("obj/my_template_pts",instancepoint(),"Cd",1) blue: point("obj/my_template_pts",instancepoint(),"Cd",2) In the same way I think you could use an attribute on your shader "offset". And put the instancepoint() in the offset, not 100 % sure though as that would require the material settings to be changed and stored in the ifd file for each instance. You can check this in a ifd file. Otherwise you could create multiple shaders (with different offsets) and simply modify the paths to the shaders. If you had 5 shaders the shaderpath would become something like: /shop/my_shader_`instancepoint()%5` But check the file, it does the same with delayed loads as procedural shaders. Edit: ah, they beat me to it Edited October 7, 2010 by pclaes Quote Link to comment Share on other sites More sharing options...
