lisux Posted October 12, 2010 Share Posted October 12, 2010 Hi all. I am tying to compile the SOP_Flatten example in a Mac Os X Leopard using hcustom. I got these errors: Making SOP_Flatten.o and /Users/pablo/Library/Preferences/houdini/11.0/dso/SOP_Flatten.dylib from SOP_Flatten.C cc1plus: warning: command line option "-fobjc-gc-only" is valid for ObjC/ObjC++ but not for C++ /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘int32 SYS_AtomicImpl::test_and_add(int32*, int)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:345: error: ‘__sync_fetch_and_add’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘int32 SYS_AtomicImpl::compare_and_swap(int32*, int32, int32)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:351: error: ‘__sync_val_compare_and_swap’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘int64 SYS_AtomicImpl::test_and_set64(int64*, int64)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:358: error: ‘__sync_lock_test_and_set’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘int64 SYS_AtomicImpl::test_and_add64(int64*, int64)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:365: error: ‘__sync_fetch_and_add’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘int64 SYS_AtomicImpl::compare_and_swap64(int64*, int64, int64)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:372: error: ‘__sync_val_compare_and_swap’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘void SYS_AtomicImpl::store(int32*, int32, SYS_MemoryOrder)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:389: error: ‘__sync_synchronize’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:399: error: ‘__sync_lock_release’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:405: error: ‘__sync_lock_test_and_set’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h: In function ‘int32 SYS_AtomicImpl::load(const int32*, SYS_MemoryOrder)’: /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:428: error: ‘__sync_synchronize’ was not declared in this scope /Library/Frameworks/Houdini.framework/Resources/toolkit/include/SYS/SYS_AtomicImpl.h:435: error: ‘__sync_val_compare_and_swap’ was not declared in this scope Compile failed I have Xcode but not sure if it is the latet version because seems I don´t have gcc-4.2 in my systems just 4.0.1. I have also tried to compile using Makefiles, with the Makefile by Sebastian Schmidt: http://www.sschmidt.subsites.org/484.0.html But same result, Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
graham Posted October 12, 2010 Share Posted October 12, 2010 Are you running OS X 10.5? Quote Link to comment Share on other sites More sharing options...
lisux Posted October 13, 2010 Author Share Posted October 13, 2010 Are you running OS X 10.5? Yep, I got the solution, I put it in my blog in case it could be useful for others: http://lisuxes.blogspot.com/2010/10/hdk-in-mac-using-hcustom.html Quote Link to comment Share on other sites More sharing options...
luke046 Posted March 18, 2011 Share Posted March 18, 2011 Hm Im trying to compile on my os x aswell.. I´ve downloaded the make file from your link. Im a bit confused here.. Can anyone break these steps down for me? I need to add the path to my cpp files and the destinaton for the .so file I assume.. but where in his code? The path on my linux makefile was like this: SOURCES = lib/FluidSolver.cpp sop/SOP_FluidSolver.cpp DSONAME = SOP_FluidSolver.so cheers Quote Link to comment Share on other sites More sharing options...
