Max_CamFOV to Houdini_CamFOV
fex
Hi all,
is there anybody out there who knows a way to convert 3dsMax FOV (deg) and Lens (mm) to Houdini Focal Length (mm) and Aperture (mm)??
Read this article "Matching Houdini Cam.." but can't use it for this one
(i'am really bad in mathmatics).
Any formula, idea or comment would help..
thanks in advance
fex
FOV in degrees is independent lens parameter instead of focal length in mm. So 50 degrees perspective is ALWAYS 50 degrees: for film, video, slide, etc.
For your task: set apperture parameters to the same values in both scenes (MAX and HIP) and copy MAX's lens to HIP
