dannyODF Posted October 30, 2010 Share Posted October 30, 2010 hey, Im using a file node to bring in a volume .bgeo sequenced that I cached. When I middle mouse click on it, it says it has two volumes. how do I separate out these volumes into separate nodes? thanks! Quote Link to comment Share on other sites More sharing options...
mawi Posted October 30, 2010 Share Posted October 30, 2010 hey, Im using a file node to bring in a volume .bgeo sequenced that I cached. When I middle mouse click on it, it says it has two volumes. how do I separate out these volumes into separate nodes? thanks! volumes are primitives. Branch of two delete nodes one deleting prim 0 and the other deleting prim 1. Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted October 30, 2010 Share Posted October 30, 2010 You should just give up dude! Haha! Welcome to the forum! Quote Link to comment Share on other sites More sharing options...
dannyODF Posted November 1, 2010 Author Share Posted November 1, 2010 (edited) Thanks guys, that worked. I am trying to mix the volumes now, but they won't mix. I suspect its because they have different indexes. Ive attached an image. When you view the information for each file node, it says each one has 1 volume, but one node's volume is at index 0, and the other is at 378. How can I set the 378 volume to 0 (hopefully that will allow them to be mixed). thanks, Edited November 1, 2010 by dannyODF Quote Link to comment Share on other sites More sharing options...
dannyODF Posted November 1, 2010 Author Share Posted November 1, 2010 I used the sort node... so intuitive! Quote Link to comment Share on other sites More sharing options...
bunker Posted November 4, 2010 Share Posted November 4, 2010 you can also delete/separate volumes by name using an expression in the group field : @name=density or to delete 3 velocity volumes at the same time : @name=vel* have fun with volumes Quote Link to comment Share on other sites More sharing options...
