hopbin9 Posted November 1, 2010 Share Posted November 1, 2010 Hi, Can Houdini do DOF and Motion Blur in COP? Quote Link to comment Share on other sites More sharing options...
malexander Posted November 1, 2010 Share Posted November 1, 2010 DOF - yes. Use a depth map piped into a Depth of Field COP, then fed into a Blur or Defocus COP's mask input, with per-pixel enabled on Blur or Defocus. Motion blur - only uniformly on an entire image element, which is a translated by a Transform COP. The Streak COP and Radial Blur COPs can also apply motion-blur-like elements to an image. The Velocity Blur COP does not operate as expected. Quote Link to comment Share on other sites More sharing options...
Macha Posted November 2, 2010 Share Posted November 2, 2010 Real motion blur is the one thing I dearly miss in COP. It would be almost perfect with it! To get a motion blur pass in the first place is a bit fiddly, and there are posts on this forum, but if you want there is a ready-made one hidden in the default fur shader. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 2, 2010 Author Share Posted November 2, 2010 Thanks guys, I'll give that a try. Sounds like Motion blur is tricky. I can do that in AfterEffects if needed. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 5, 2010 Author Share Posted November 5, 2010 Noob question: How do I create a depth map material in Houdini? Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 5, 2010 Author Share Posted November 5, 2010 Oh, I think I figured it out. Just add a Pz plane to the render output. Quote Link to comment Share on other sites More sharing options...
