Macha Posted November 6, 2010 Share Posted November 6, 2010 (edited) Ahh, for some reason I stumble over this: I want to extract u or v curves from a NURBS surface so that I can use them individually for lofting. I tried various things such as ends sop, carve sop, convert sop, etc, but I always end up with an invisible NURBS surface and a bunch of curves that consist of just one primitive or something else I can't extract the curves from. How do I do this? puzzled.hipnc Edited November 6, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
anim Posted November 6, 2010 Share Posted November 6, 2010 try Convert SOP to polygons - Rows for U, Columns for V - Interpolate through hulls Convert SOP to NURBS curve - maybe play with U order Quote Link to comment Share on other sites More sharing options...
Macha Posted November 7, 2010 Author Share Posted November 7, 2010 Yes, you're right, something like this works. It's not perfect yet but good enough for what I do. Thanks. uvcurves.hipnc Quote Link to comment Share on other sites More sharing options...
kubabuk Posted November 7, 2010 Share Posted November 7, 2010 use the carve sop and increase u divisions, see attached file puzzled_carve.hipnc Quote Link to comment Share on other sites More sharing options...
Macha Posted November 7, 2010 Author Share Posted November 7, 2010 Thanks Kuba. In fact if I set it to breakpoints I get the exact original curves. Solved! use the carve sop and increase u divisions, see attached file Quote Link to comment Share on other sites More sharing options...
