thom Posted November 6, 2010 Share Posted November 6, 2010 (edited) Hi, I have an annoying problem, when i tried to open some scene from others(downloaded file from sidefx website), Houdini crash. I'm running fedora 14 and Houdini 11. Any idea about where the problem can came from ? thanks in advance, Thom. Edited November 6, 2010 by thom Quote Link to comment Share on other sites More sharing options...
jason_slab Posted November 6, 2010 Share Posted November 6, 2010 you using the latest build of Houdini, or could it be an older build than the scenes your downloading? i've been having problems with Houdini 11 and backward compatibility.. jason Quote Link to comment Share on other sites More sharing options...
iamyoukou Posted January 7, 2017 Share Posted January 7, 2017 On 11/6/2010 at 4:26 PM, jason_slab said: you using the latest build of Houdini, or could it be an older build than the scenes your downloading? i've been having problems with Houdini 11 and backward compatibility.. jason I think you're right. When I try to open hic (build with H13) with H14 or H15, Houdini crashes. Or when I try to switch hic (build with H13) to hic (build with H14 or H15), Houdini crashes. So I think the best way is to re-create that hic in the newest Houdini. Quote Link to comment Share on other sites More sharing options...
