Camera look at particle
This falls under the category of point constraint in Houdini.
Two ways off the top of my head and both create a second object to follow the point along and then use the look-at object parameter in the camera:
1. Rivet Object
2. point() expression
2a. Add vtorigin() + point() to account for any transforms on the target object with the particles.
With the Rivet Object, you can use the viewport/shelf tool to interactively select the point you wish to "rivet" to.
See the attached example file.
I assume you know that if the particle dies, you loose your center of interest. Yes there are ways to provide fall-back logic to handle this but just so you know.
