Houdini<->Real Flow ROP/IFD
Guest xionmark
Guest xionmark
Hi everyone,
Houdini Real Flow ROP/IFD plugin is now available for general
consumption.
>From the web page:
"The Real Flow SD File Export ROP/IFD (Render Operator) will export
Houdini geometry to Real Flow SD (Scene Description) files. This ROP
will support multiple objects and camera data (camera data will be
working in the next release). The Real Flow SD file supports a feature
called "Matrix or Vertex Mode". "Matrix Mode" will simply output the
objects geometry only once, but the object's transformation data for
each frame in the animation. "Vertex Mode" will output geometry for each
frame but ignores the objects transformation at the object level, which
allows geometry deformations to appear in the SD file (This may be
changed in the future to support both modes at once)."
Here's the URL:
http://www.digitalcinemaarts.com/dev/real_flow/
Linux version will follow shortly. As before, please report any bugs to
support@digitalcinemaarts.com. To date, there's been over a hundred
downloads and I know of about a dozen people evaluating and/or using it
in production (and no bug reports! ... keeping fingers crossed ...).
Now that I've finished "sketching" out the interface between Houdini and
Real Flow, (and before I dive into refining , optimizing and adding more
features to the code) I will have more detailed step by step tutorials
over the next month. Got lots more planned!
Have fun!
--Mark
Guest xionmark
Hi there,
I think Real Flow is a good compliment to Houdini. Houdini has by far the easiest and most flexible particle
system of all the major 3D applications, but Houdini doesn't have true CFD (computational fluid dynamics) yet.
What's also nice is that for Select users, you can use Real Flow for very elaborate fluid simulations and not to
try to do it all in the very few particle related SOPs, considering of course that Select has no POPs.
I would think SESI is working on CFD considering Houdini's dominant position in the effects market. However,
I was amazed that at this year's SIGGRAPH, there were many course on fluid dyanaimcs, water, water, everywhere!
And Houdini was not mentioned very often ... I gotta think SESI is cooking up something pretty amazing though!
--Mark
  • 1 month later...
Guest xionmark
Hi there,
Just a quick note to let you know the Linux version of the Houdini-Real
Flow plugins are all working now and available at:
www.digitalcinemaarts.com/dev/real_flow/download
I'll be doing a "rewrite" of the plugins over the next week to clean
them up and get them out of "beta", after which I'll be developing a few
different POP's for Real Flow so one can import the Real Flow particle
files right into POP's, as if they were a generator. And I'm adding
particle systems inside the SOP instead of just points, and a bunch of
other things to optimize and make it easier for the user to "integrate"
the 2 applications.
If there's a need for support or training, I'm available at competitive rates. :-)
--Mark
