laser ray creating in houdini.....frome curve
salam evryone i try to creat laser light from curve as in laser weapon project (video on vimeo site_and it is done in houdini)
if any one know some setting about this or can help me with very little hip file it will be welcome , i have try all what i know with out any result..............help please ............
if you are referring to this thread:
at that time there wasn't a geometry light in Houdini (at least I think so), so I faked it instancing a light to the points along the laser... for my purposes it did the job, now could be more interesting try the new geometry lights.
Sorry if I didn't attach you any hip file, but as you can see it's really easy to do it...
- just create a light,
- in your geometry (your laser line) make visible the instance tab
- and toggle on the point instancing and connect your light there.
Hope that helps.
Cheers,
Emanuele
A line area-light works well too, especially if you surround it with fog.
Other things to try would be a tube with emission switched on in the shader.
Or, best perhaps to do it in post.
By coincidence I just did such an effect here:
Edited by Macha
