switching from one static object to another....
crash0283
Hey guys
I'm in the process of shattering a wine glass with particle fluid in it. I have two static rbd objects that are written out to file, then read back in to interact with the fluid. The only problem I have is that when I place a switch node in the network to switch between the whole glass and the fractured glass simulation it doesn't work. I keyframed the the switch node and right when its suppose to switch to the fractured glass...it doesn't show up. I've tried using separate solvers, but that didn't work either. I would really appreciate any suggestions. Thanks
Chris
