How to bring to DOPs chunks created in SOP
tayga
Hi all
I'm trying to fracture an object based on attributes modified with SOP solver. On SOP level new pieces are created just fine. But I don't know how to bring those chunks back to DOP simulation. Plus I have strange behavior on frame 1 when I bring just single piece. RBD Fracture Object doesn't work because number of pieces changes over time.
How would you dynamically create new objects in DOP?
Thanks for the help.
section_split_odforce.hipnc
Here is my solution. I used CHOPs to procedurally get the frames that new pieces need to be made and isolate the new pieces.
Hope this helps.
Make sure you run the cache node in SOPs and recook the voronoi fracture SOP before you run the sim. I get errors if I don't.
