akirasun Posted December 16, 2010 Share Posted December 16, 2010 Hi there , I have spent several days on a experimental project(for practicing). I attempted to do is , try to find a way that can fill & generate objects in a reference object(for instance inside a cube) without any penetration or any intersection with each other. I used a “iso offset node” and “scatter node” to achieve generation of random points in a cube , then sent all points to a ”VOPSOP node”. I concerned a algorithm for VOPSOP , see below for (i=0;i<pointCount;i++) { if i.color !=<<1,1,1>> { for (j=0;j<pointCount;j++) { if distance(i,j) < radius && (i != J) { j.color = <<1,1,1>> } } } } And here is my SOP Network and VOPSOP Network. Maybe I did completely wrong ,hope someone can point it out. Thanks in advence Volume_03.hipnc Quote Link to comment Share on other sites More sharing options...
