spin quads in houdini... exist?
dyei nightmare
so, now i will turn the tread to this question: do you think organic modeling in houdini is doable?
You probably mean subdivision surface modeling. Sure it's doable, mut not as sleek as in official modeling softwares. Then again using houdini's procedural modeling system you can generate some controlled detail that you'll never get from the other packages or it at least would require tons of serious scripting or plugin development.
