djbyun Posted December 31, 2010 Share Posted December 31, 2010 Hi, How could I get attributes' values of last frame? DJ Quote Link to comment Share on other sites More sharing options...
Macha Posted December 31, 2010 Share Posted December 31, 2010 (edited) $RFEND will give you the value of the last frame. If you mean any attribute of your geometry, try the timeshift sop, you can then get at that timeshifted attribute with an expression in any node. Another way to get at future data are chops. However, all this will not easily work if you have a network that is history dependant such as pops or dops. In that case I would write your geometry or simulation to disk and get it from there. I find that the best way to work is to reduce as much history dependence as possible. This is often not possible but if you keep that in mind you can make more stable networks. Edited December 31, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 3, 2011 Share Posted January 3, 2011 Yup. It´s a stability vs procedurality issue there. I do think Doc Emmet Brown was right about playing with the future Quote Link to comment Share on other sites More sharing options...
bma831 Posted January 7, 2011 Share Posted January 7, 2011 $RFEND will give you the value of the last frame. If you mean any attribute of your geometry, try the timeshift sop, you can then get at that timeshifted attribute with an expression in any node. Another way to get at future data are chops. However, all this will not easily work if you have a network that is history dependant such as pops or dops. In that case I would write your geometry or simulation to disk and get it from there. I find that the best way to work is to reduce as much history dependence as possible. This is often not possible but if you keep that in mind you can make more stable networks. can you explain this a little bit more? as an example, i am adding points to a group as the group's bounding geometry grows, when added the points turn from white to red. can i use timeshift sop or chops to get the frame that each points color changes? i would like to use this attribute as the starting point for animation cycles that are copied to each point (ie a sphere scales from 0 to 10 starting when the point enters the group/turns red) maybe this isnt even what you are talking about but if it is then let me know. thanks! Quote Link to comment Share on other sites More sharing options...
Macha Posted January 7, 2011 Share Posted January 7, 2011 (edited) Hm. I only know part of the answer. Perhaps somebody else on this board can help us. I attached a file in which points are added to a growing group. An ingrp attribute is then passed to a chopnet. You can see in the chopnet at what frame each point enters the group. The next task would be to write that frame number (when the ingrp channel for that point jumps from 0 to 1) as an attribute. Perhaps there is an chop expression or a node somewhere for that. Maybe the lookup chop. That's assuming you really need all this. Can't you get away with checking groups on the current frame by using haspoint()? testgrp.hip Edited January 7, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
Macha Posted January 7, 2011 Share Posted January 7, 2011 This appears to work. It gives you an attribute telling you the frame number at which the point enters the group. Phew, that was tricky. I don't know much about Chops! testgrp.hip Quote Link to comment Share on other sites More sharing options...
