willlinks Posted January 3, 2011 Share Posted January 3, 2011 Hi everyone, A Happy New Year! I got a problem with using attribute $ID from POP in Trail SOP. The Trail SOP is simply connected to POP and I can see the attributes for each particles in details view. However, I can't use them as local variable in the Trail SOP... Anyone knows good solution for that? Thanks. Hiro Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 3, 2011 Share Posted January 3, 2011 It´s difficult to help without being sure of what you want to do. In the past I have solved some of these "SOP nodes not watching POP attributes" by creating the attribute myself in SOPs and giving it the POP attribute value. Quote Link to comment Share on other sites More sharing options...
willlinks Posted January 3, 2011 Author Share Posted January 3, 2011 Hi Javier, Thanks for replying. What I want to do is using particle id for length of trail in Trail SOP. I attached a file. If you don't mind, please have a look. Thank you so much ParticleTrail.hip Quote Link to comment Share on other sites More sharing options...
sanostol Posted January 3, 2011 Share Posted January 3, 2011 (edited) the trail does not support local variables but You can splitt particles as trails from Your particles leaving a point trail, and by setting the right lifetime it would work. in sop You can now use the add sop to connect them by the parent attribute have a look at the demofile Hi Javier, Thanks for replying. What I want to do is using particle id for length of trail in Trail SOP. I attached a file. If you don't mind, please have a look. Thank you so much trails.hip Edited January 3, 2011 by sanostol Quote Link to comment Share on other sites More sharing options...
willlinks Posted January 3, 2011 Author Share Posted January 3, 2011 Hi, Martin. That's a great idea!! I appreciate it. And thanks for attaching file as well:D the trail does not support local variables but You can splitt particles as trails from Your particles leaving a point trail, and by setting the right lifetime it would work. in sop You can now use the add sop to connect them by the parent attribute have a look at the demofile Quote Link to comment Share on other sites More sharing options...
