l-systems and elastic cloth object ...
roughsporty
I tried to use an l-system gnarly tree preset with an elastic cloth object to fall on a ground.
After 20 minutes of sim stuck on frame 1 I canceled the job.
What I have to consider when I use a l-system as a softbody cloth object?
I think it´s bad to simulates cloth with a mesh that self penetrates like that.
Maybe take of the L-system tubes and simulate it as wires?
Maybe a Squichy Object will do the trick. I'm building different flowers with l-system but first I will do some research because I've never used it before.
The wire solution makes sense but than you have to build wires proceduraly on the l-system skeleton. I don't know if it is an easy task.
Edited by roughsporty
